Engine cranking without key on
skeeterfishin
36
Jul 19, 2006
frankfort, Indiana
Ok, i just bought the car it has no ecu in it, no problem probably needed new one anyway. in the meantime i am doing a little maintnance and cleaning, hooked up battery and as soon as i did the engine started cranking over. Could this be because it has no ecu in the car? or a stuck solenoid? .
Stuck starter solenoid. Remove the solenoid from the started and see if the spring is broken. If not, clean the solenoid and piston, lube with lithium grease, and try it again. Mine had that problem after it sat for a long time. It was just the solenoid had gummed up from a previous oil leak.
ahh, i kinda thought it might be the solenoid just stuck since the car has been sitting for a few years, thanks
well, i whent and took out the starter. good thing solenoid got stuck ### the starter would be going before long, had alot of plat in it like the bearings were shot.
thanks again for the reply
