engine bogging when cold
bulletproof96
Mar 4, 2007
houston, Texas
ok so heres the deal my car takes a while to start when cold, it will actually start only if i play with the gas pedal a little bit. then after it starts it idles at about 700 to 800 rpms and if i don't keep pressing the gas pedal then it will die. After it warms up then it actually stays on and running descent but it will idle at about 1500 rpms. what can be the problem any suggestion will help thanx.
