Engine and Transmisison Swap
91TalonTSi_53
164
Apr 1, 2002
Minnesota
Alright, I just got asked if I would do some work for a guy.
He asked if I would swap a 2.0 into his eclipse which has a 1.8 right now, and he said he had another car that he wanted me to swap the transmission from. So what he has is 3 talons/eclipses and one has a good engine one has a good tranny and the other one has too small of an engine/no turbo.
Now what I am asking you guys/gals is, about how long of a project would this be, and I really don't know what I should charge him. I haven't taken an engine out of one of these cars yet, I have taken a trans. I am confident in that I can do it, I just don't know what kind of time frame I am looking at, and if there's something that I am just not thinking about that would make this more work than it's worth.
Any input would be appreciated, Thanks.
my guess is turbo because he posted that the one car has a small engine w/ no turbo...i dont think he would specify no turbo, unless he planned on upgrading to a 2.0L turbo motor :thumb:
You have to aslo have to swap the wiring harness if you are going from a N/T to T. Sounds like more trouble that what it is worth. I dont think the motor mounts will interchange aslo. Perhaps you should search to see if it can be done first. If everything goes right, it wont, then I would say a good solid day could have them swapped.
Michael
:talon: :laser:
98TsiAWD said:
That might be alot fo work, if I was you I would talk him into swapping the good trans into the car that has the 2.0l in it already.
I am assuming that there is body damage on the car with the good transmission or something else that makes the chassis unusable, or that he has the 1.8 litre car fixed up to look the way he wants the car.
u wont need to change the ecu wire harness,the only difference between the harness is like 4 wires all u need to do is cut four wires and add 4 more,search the internet its directions are somewhere.
