engine and tranny oil questions
Snail Tuning
68
Feb 5, 2005
Smithville, Ohio
i did a search on oil and got pressure and nothing on what oil weights to use.
on honda's i would use 10w30 for pre96 engines, and 5w30 for anything newer than 95.
so what weight do you guys use?
i bought some 10w30 moble 1 to try out and see how i like it. (i only run moble 1 fully synthetic in turbo cars. ive had no problems with it.)
also on the tranny, what fluid for the tranny, and also the transfer case. and also the clutch line. (in honda's we use brake fluid, didn;t know if it was the same.)
the little trip around the block my gears all grinded, and so does reverse. so i need to findout how to adust the clutch, and also check all of my fluid levels.
thanks for the help!!! :thumb:
also i need to know where i can get a new plug terminals and wire for the transistor pack.
thanks
