Emissions check with DSMLink
Omega
1,558
10
Oct 10, 2002
Randolph, New Jersey
In NJ they check for codes and a few other things during inspection. On the DSMLink they mention something about "DSMLink mode" I assume that is only when you are making changes to the settings.
I figure since you can use a logger with it installed, the inspection check should be ok... but I want to make sure.
I don't know anything about what they look for during inspections or anything, but you only need to have your computer plugged up to the OBD port when you are making changes. If they plug their reader into the OBD port, just make sure your logger is unplugged and you should be fine.
That exactly what I was looking for.. thanks.
That depends. Considering the only way to get the car run correctly... or properly for that matter is to use an AFC/DSMLink and so on.
Only a properly tuned engine will pass... regardless of what fuel/engine management system you use.
Here NJ they check the OBD and I wasn't sure if the DSMLink would interfere with this part of the check.
