emission delete kinda confused
"awdtalon"
Jul 21, 2012
jenks, Oklahoma
Ok so i did the emissions delete on the talon first off do i need to run the vacuum to the fuel pressure solenoid then to the reulator or can i direct line it. then when i bought the car had a cone filter on the intake and no boost controll solenoid on it or manual boost controller could that be a cause of some boost lag. then i keep reading u shouldn't t the bov line the runs to the intake so if thats the case where di i run the vacuum off the waste gate thats where i have it running to so what is the correct way to do this or is this right.:confused:
Yes, you can run a vacuum line straight to the FPR. The solenoid is only to assist with hot starts. If you don't have a boost control, then run a line straight from the turbo to the wastegate. If your on the stock turbo there should be a barb fitting right on the j-pipe.
ok i have my boost gauge running off of the jpipe can i just t it or move the boost gauge somewhere else
no on here i read that you shouldn't t the bov line that u can hook it to the nipple on the jpipe so im guessing they were wrong so where do i hook it put a t before the fpr or what
[QUOTE="awdtalon";153052893]no on here i read that you shouldn't t the bov line that u can hook it to the nipple on the jpipe so im guessing they were wrong so where do i hook it put a t before the fpr or what[/QUOTE]
You want the BOV to be connected to a source anywhere after the throttle body so that it gets a vacuum signal. You can T into the FPR for the boost gauge, but it would be best to give it it's own source such as the nipples on the throttle body. I forget which nipple receives boost and vacuum so I suggest researching it.
