RiceKiller_TSi
- 2,938
- 12
- Nov 21, 2003
Mobile,
Alabama
Originally posted by Mike 99GSX
NPT stands for national pipe thread. 1/8 NPT is slightly larger than the threads that are in there right now. What I am suggesting is: go to a harware store and buy a 1/8" NPT tap because aftermarket straight fittings are going to be in this size and pitch because it is a standard. ( You will never find a straight fitting that is the same thread as what the Mitsu PCV valve is). Make your new hole and get a straight fitting. Then go to a Napa or Autozone and get a PCV valve that is 1/8" NPT to match your new hole instead of the Mitsu one. That way you can swap it back in if you have to. I hope this clears it up.
And it does! Thanks alot! Im about to chase some holes and tap em!
.. but since yours is a NT and you've removed the breather and PCV line... the only other avenues for oil consumption is Head Gasket, Oil Rings and Valve Seals.
