JoeyJigglesGSX
- 223
- 0
- Jun 20, 2003
Wilmington,
Delaware
just as the title says...what is the difference between an electronic boost gauge and a mechanical?
Quasimondo said:Mechanical boost controllers are inexpensive, simple to install, simple to use, but you have to pop the hood every time you want to adjust your boost settings.
Electronic boost controllers are expensive, somewhat complex to use (a bi*** for daily driving if you have one that uses fuzzy logic). don't need to pop the hood to adjust.
Unless you're always in a constant state of tune with your car save your money and go with a reliable manual boost controller, with most daily driven cars, boost is a "set it and forget it" kind of thing
DSMcamaro said:hes asking about gauges... not controllers.
Quasimondo said:Damnit, I'm a fool.....
Electronic gauges don't require you to run that crappy, easy to kink nylon line through the firewall for one. Instead it monitors boost through a MAP sensor.
JoeyJigglesGSX said:do you guys think that electronic guages are innacurate?
