electrical problem pls help!!!!
on_campus15
36
May 28, 2008
ottawa,
Ive pretty much read all the other post..none correspond to mine!!!
what im in the process of doing is a body swap, my old 95 talon was alitle
rotten..so ive changed my body..
Now ive pluged almost all my wiring exept for the engine bay wiring...
and my brake lights wont turn off unless i pull the fuse out in the engine bay..
unpluging the brake pedel switch wont do me any good they still stay on..
my brake fluid level is good...
does anyone know if there is a relay somewere in the car or
ground that i could be missing???????????/
Try replacing the Brake Light Switch..common for older cars, it sounds like that is the problem since, the lights go out when you disconnect the circuit.
-Zach
