electrical or timing
joby66
Aug 24, 2012
argos, Indiana
Have an 89 colt gt turbo, had an oil leak that shorted the altenator and fried the battery(hot). Believing leak was from front crank seal, I replaced it, the altenator and the battery. Now it won't start. Has fire to plugs, fuel squirts from the line to the fuel rail. Check engine light doesn't stay on but keeps getting the code for the crank angle sensor. Can't afford a new one so put one in from junk yard, still something. Done belt couple times before, but will cam timing marks be exactly in line or will both outside marks be a half a tooth higher. Will something in timing give the code for the crank angle sensor. Electricly the lights on and all seems ok except one time the passenger seatbelt went haywire(jerky) but is fime now. So why the code, does it have to be the sensor is bad or can something else(like timing) give the code?
Timing will not give the code. If you've got a code for the CAS then trace down that circuit and find out why. The timing marks should be dead on. Look at the inside marks on the cams. Crank must be dead nuts on or looking at the cams is worthless. Everything is relative to the crank.
So a CAS that I know is working is a good place to start, does somebody know somebody with a working one.
Remember for the 4g61t you need either a 89 or 90' CAS, also the 89' CSMs use a longer wire loom than the DSMs so you may need to undo a few grommets on the firewall plug to make the shorter DSM CAS wires reach, also take into consideration engine movement.
Check base ignition timing and adjust the CAS properly.
If you don't know about them already I suggest checking this forum out.. 4g61t.org • Index page
Also, there is no Mirage GT, the only GT is the Colt, the Mirage is just Mirage turbo.
Mirage turbo
Colt GT
:p
did the CAS test mentioned in link but left it in and used the motor to turn it over,tested ok(a little weak on crank wire volt.) but was acting like it wanted to fire. Move CAS clockwise a bunch and gave it a little throttle and it started.Did that earlier and it wouldn't. After I set timing I think it should be ok....thanx.
