Electrical harness rebuild questions
Calan
DSM Wiseman
7,250
398
Jan 16, 2007
OKC, Oklahoma
1. Where can I find new replacement connectors? Specifically, I need all the connectors for the water neck sensors, and the 2 male and female connectors that plug together just under the bottom of the fuse box. Probably wouldn't hurt to pick up new ones for the CAS and TPS also.
2. What is a good high-temp loom and tape to use?
Since our cars (assuming your refering to the 1g in your profile) are getting old, it's becoming difficult. So making your own connectors or "stealing" them off cars in the junk yards is becoming the most common way. I've personally not tried getting connectors from Mitsubishi or Hyundai but I would think most are no longer available. Sorry to disappoint.
Kinda figured that... but anything in a junkyard probably won't be as good as the ones I'm replacing :). What's a good alternative?
Can I get other matching male/female auto connectors (and a good tool) somewhere? Like maybe some of the GM style connectors?
Just discovered I also need the male/female connector at the brake fluid reservoir...I guess it's for a brake CEL?
  • For sale 420A 420a block & EGR/ FUEL RAIL INJECTORS
    90PSI compression test. Possible damaged piston rings, unsure. Possibly good for a...
    • Stizzydrew
  • For sale 420A OEM 420a throttle body
    $40 + shipping + fees (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a intake manifold
    $80 OBO + shipping + fees. (PayPal) Pick up CA 91605
    • Stizzydrew
  • For sale 420A 420a thermostat housing
    Oem thermostat housing 420a $20 + shipping + fees.
    • Stizzydrew
  • For sale 420A NVG T350
    New venture gear T350 M/T 420a
    • Stizzydrew
