blcknspo0ln
DSM Wiseman
- 7,772
- 102
- Jul 31, 2003
Central,
New Jersey
Ok, where do I start? Bear with me since I am an intense electrical idiot. Cylinders 1&4 fire and 2&3 do not. I have confirmed that the coil pack DOES NOT fire, hence the pair of cylinders not working correctly. I have 150 psi compression across on a freshly re-ringed motor (cold, WOT), verified mechanical timing, verified fuel in all 4 cylinders. I have also spark tested and confirmed that 1&4 fire and 2&3 do not.
Replaced:
-3 different 1G CAS, positioned TDC
-new taylor spark wires
-new NGK BPR7ES @ .028
-swapped to a verified working power transistor
-swapped to a verified working coil pack (plus resistance tested)
-verified working 99 ECU swap
Grounds: Only grounds I know of are the two to the negative post of the battery, which leads to the firewall and trans bellhousing.
After finding this I gave it a go for continuity test (I'm testing for 0 ohms across, right?)
- Coil pin 1 (blue/black) to PT pin 1 (blue/black). CHECK
- Coil pin 2 (blue/red) to PT pin 8 (black/white). CHECK
- PT pin 3 (black) to ground. CHECK
How do I verify? Simply use some really long wire and reach into the cabin at the ECU harness?
- PT pin 2 (brown/red) to ECU pin 23 (brown/red). Did not verify yet
- PT pin 7 (black/blue) to ECU pin 10 (black/blue). Did not verify yet
Some other things I gathered, not too sure of its importance. these tests were done with both plugs unplugged from transistor&coilpack.
Power transistor KEY ON voltage test:
1 - 1.15V
2- 0V
3- 11.8V
4- --
5- 8.3V
6- 0V
7- 0V
8- 0V
Coil pack plug KEY ON voltage test:
blue/red - .96V
blue/black - 0V
blk - 11.8V
CAS plug KEY ON voltage test:
black/yellow : 0V
red/silver: 11.8V
red/silver: 5V
note: I noticed when I accidentally grounded this during the test, the ISC made a lot of whirring noises.???
red/black: 5V
The ISC also does do the whirring sound when the ECU clicks OFF after I remove the key
Replaced:
1 - 1.15V
2- 0V
3- 11.8V
4- --
5- 8.3V
6- 0V
7- 0V
8- 0V
blue/red - .96V
blue/black - 0V
blk - 11.8V
black/yellow : 0V
red/silver: 11.8V
red/silver: 5V
red/black: 5V
Now.. on to dealing with that horrid boost leak that developed
