EGT gauge problem
justinhill98gst
190
Sep 1, 2007
White bEAR laKE, Minnesota
It started to happen out of the blue the gauge will tweak out then the needale will just sit on the bottum of the gauge, I checked the sensor on the exhaust manifold it came out and it was loose so i tightented it up a bit but nothing. Could the guage and the hole setup be worn out? has this happen to anyone else? also it autometer
Yeah the EGT probes are downright finicky. They go out frequently especially in a hot running car like a DSM.
yes. Do they sell the sensors at any place that sell them kind of gauges? BTW i love the look of your dsm
Thanks:D I'd give summit racing( 1-800-230-3030 or 1-330-630-3030,http://www.summitracing.com/) a call, they should be able to tell you what part # you need and if they have it in stock. If anything get the part# for the replacement thermocoupler and shop around for the best price. Good luck:thumb:
When I had an EGT gauge, this was due to crappy wiring. Check over it again before you drop the money for a new sensor.
I had a problem with an Autometer EGT gauge. Whenever I would start the car, the needle would go up quick then fall to the bottom. It was due to a bad gauge, but mine was brand new and it just wasn't calibrated right. Not sure if that would be it or not
