EGR Temp Sensor question
Champ Masters
36
Jan 22, 2006
Stockton, California
Hi all,
I recently pulled the motor out of my 1992 6-bolt GSX. I've been in the process of going through it replacing things that are old or worn out and I came across something strange. On the EGR Temp sensor, there is some sort of sheath covering the wire that goes from the sensor to the wire harness connector. I noticed some kind of oil coming from inside the sheath. When I pulled the sheath back there was oil covering the wires. I inspected the sensor itself and there's no fluid coming out or around it and before I pulled the motor I didn't have any CEL's. So my question is, is this normal? Or is this a sign that the sensor is starting to go bad and I should replace it? Any help is most appreciated. Thanks!:dsm:
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
