ECUflash ECUFlash program problems?
Ppayer38
317
3
Jul 1, 2009
Smithfield, Virginia
Edit postDelete postReport this postReply with quoteECUFlash program problems
by ppayer38 » Tue Jun 14, 2011 1:18 pm
Like the title says im having problems with the tunes and ECUFlash progrram...
*This all started after my computer crashed and I was able to save all my tunes, my work, and pictures*
-My maps went back to stock size after I had a patch done for the bigger sized maps(Big Maps) and I do not know why...
-When I change the setting from beginner to advanced nothing seems to change at all so
-Some of the options are not there like fan on/off temp settings
-Some of my tunes will not open even though I had all the right stuff downloaded and in place....
Car: 98 Mitsubishi Eclipse GSX using ECUFlash and Ceddy Mods
Any help you could offer me would be greatly appriciated as this is all I need to finish up my car and get it running!!!
Thanks,
Josh
Already on that but it takes time with him as we know he is a busy man... haha
Also have a call/emial into Tactrix to try and get this sorted out just incase it is a program installion problem on my end....
If you have a copy of the 20550011 DEF please post it so I can try it...
So far ive tried:
-Unistalling program and reinstalling it
-Uninstalling and reinstalling ROM's and DEF's(Maybe ive got the wrong files?)
So any ideas or things you guys can think of would be of great help and of appriciation
Your probably mixing old files up you can't mix definitions and rom versions. Try not using any of the old files you have.
Try deleting ecuflash and reinstall
download a fresh copy of the ceddymods zip he sent you in your email
you cannot use the 2055 file that gets installed with ecuflash it will brick your ecu delete it.
then follow the directions i gave you in the other thread
Ok so basically what you were saying is parcially true...
I tried to download the 2055 file from ceddy's site and it seemed to be the problem(not sure if it was cause it was old or what the issue was)
I talked to Ceddy and he sent me the zip file that has stock, big maps, 2055 xml and everything I needed to do anything pretty much which is mroe than I need but anyway I got it going again!
I just have to say thank you to Ceddy for the help and that some donation's are deffinetly coming your way for the help!
Thanks to everybody for trying to help but it seems to be the 2055 xml file was the issue but solved now!!!
