ECU wire taps/hooking up WB
Calan
DSM Wiseman
7,250
401
Jan 16, 2007
OKC, Oklahoma
I'm hooking up my Zeitronix WBO2.... can I just splice the controller signals into the wires at the ECU connectors, or will it cause some input loading or impedance problems at the ECU?
The wires I'm looking at tapping into are:
Pin 101: Ground
Pin 4: Stock O2 sensor (cut this and hook up the Zeitronix narrowband signal?)
Pin 15: EGR temp - Connecting WB signal out to this, to use with MMCd for logging WBO2 through it's EGRT input.
Pin 19: TPS
Pin 21: CAS (RPM) - is this a correct place to tap RPM?
I'd like to tap into switched ignition power here as well (since I'm already tapping wires), but I can't see a switched 12v ignition pin on the ECU diagram. Is there one? If not, I'll just run off the fusebox.
Thanks for any help....
I have the 1G ECU pinout diagram... but which is the ignition only 12v?
Pin 103: "Battery backup"
Pin 102: "Power Supply"
Pin 110: "Ignition switch - 1G" (12v supply or some sensor level saying the ignition is on?)
Pin 108: "Ignition switch - ST" (What is ST?)
I just need to know which pin of the ECU sees constant 12vdc only when the ignition is on.
Pin 101 (and 106) is ground.
Pin 102 (and 107) is the MPI power circuit. It gets 12v when the ignition is turned on.
Pin 103 is backup power. It's on all the time to maintain the setting in the radio and ECU.
Pin 108 is the signal from the ignition switch START position.
Pin 110 is the signal from the ignition switch START and RUN positions.
Steve
Steve
Thanks Steve... so I guess powering the WB from 102 or 107 would work just fine?
