Resolved Ecu screw stripped?
SNAKE_15
571
48
Aug 28, 2012
Bakersfield, California
I'm having trouble opening my ecu and I believed I stripped one screw. These screws are in tight :banghead: I used a flat head and tried my hardest to loosen these screws but I bent the outer edges.It looks impossible now to put the screwdriver in.
I'm scared to try on the other ones. What should I do??? I'm suppose to send my ecu for a socket service, but I'm stuck on this part. :banghead: Is this screw done for?? I got impatient and rushed important steps of what was supposed to be an easy process.
Use the vice grips as mentioned, or cut a deep slot in it and try again. Are those phillips screws? Why were you using a flathead?
