1G ECU question??
Please. I asked you to do this the other day. Save yourself some headaches and do it now.
Thanks to our friends at the Manual CD site you can download the 1G fuel system section from http://www.ecanfix.com/users/manualcd/gift/dsm/1gfuelsystem_troubleshooting.pdf and look at the MPI diagrams for the different models.
The ECU is part of the MPI circuit. Not only would this have helped you answer your question about your N/T MAF but it will tell you everything else about the ECU and it's wiring. NT AT MT and turbo versions.
You can also download the 1G circuit diagrams http://www.ecanfix.com/users/manualcd/gift/dsm/1g_circuit_diagram.pdf
That section also includes the MPI diagrams plus most of the rest of the wiring in the car.
Steve
sorry steve,
I looked over the diagram and found where each pin would connect to the 2g mas but, I'm having trouble trying to place the "Volume air flow sensor reset signal" Is this sensor like the TPS in 1g's??
