Resolved ECU Protective Coating?
Devilsfutbol17
407
48
Jul 27, 2007
Bellingham, Washington
Hey I just saw a picture of an ecu that was cleaned to where the clear protective film was pulled up around the area and the ecu appeared to have little signs of rusting around the soldered connections. What is the protective coating that is on the ecu and where can I get it? Thanks
Solution
It's called a conformal coating and the waxy type originally used is more for volume production since it heated up and the board are dipped in it. They are various type of spray on conformal coatings sold at electronic supply shops.
Solution
Alright thanks Steve. I'll go and check it out. I searched but didn't see anything pop up for radio shack or walmart. I'll have to find some electrical supply shops around here. Do you normally put some coating on ECUs after you finish working on them? I'm not in a rust prone area, but I'd rather be safe then sorry. Thanks again
  • Wanted 1g MB668570 front ABS Ring for 1992 D27A
    I would really need front ABS rotors for my 1992 D27A eclipse with AWD. Would really appreciate...
    • Gurkigg
  • For sale 1g Awd rear calipers
    Have a set ( left and right) rear calipers came off of a 91 talon awd. Freshly rebuilt. Asking...
    • Jowens1185
  • For sale AGT 52MM Bolt-On Turbo Setup
    Selling my old turbo setup, made roughly 52Xawhp/4XXtq @ 30PSI (not officially measured on dyno)...
    • Pushed
  • For sale 2g 2GB Eclipse OEM Fog Light Bezels
    2GB Eclipse OEM Fog Light Bezels $45 + shipping & paypal feesYou must be registered to see...
  • For sale 2g 2G Sun Visor Set ( with home buttons for garage door )
    2G Sun Visor Set ( with home buttons for garage door ) $45 + shipping & paypal feesYou must be...
