Resolved 1G ECU ground/ECU boots intermittent
my ecu dropped out. cel light stayed on and boost gauge did not center. was recently socketed and refurbed by ecmtuning so i was thinking i might have a grounding issue causing it not to power up.
I checked them with a multimeter and traced them about a ft up the harness. The Ground under the passenger dash speaker at the center were good but I had intermittent continuity one of the ecu grounds. I tapped into the grounds and ran new ones to the center.
f*** no. Worked for about a week then started to boot intermittent again. Pulled pins 102 107 103 101 106 and expanded the tabs for solid connection. Has good ground on dvom. Pulls mpi relay closed have power at 102 107 103 and switched power at 110. Ecu looks immaculate. New caps from ecm tuning and socket from po and don't see any signs of damage or corrosion. Cleaned it with deoxit g5 then crc qd for good measure. Boost gauge went to zero and cel went off after 5 seconds 5 or 6 times after plugging it back in then nothing.
Boost gauge dropped dead. Engine stopped when car was running like it would if you turned the key off but ecu still had power across the board. I checked voltages at the inside of the ecu from the backside of the connector. Voltages matched battery 12.6v and held constant.
  • For sale 1g 1G Eprom ECU
    1G Eprom ECU $185 + shipping & paypal fees* great for someone with a 1G or GVR4 who wants to...
  • For sale 1g 1G Ortiz Center Vent Dual Gauge Pod ( discontinued )
    1G Ortiz Center Vent Gauge Pod $100 + shipping & paypal fees* long discontinued * gauges are...
  • For sale 1g 1GA Clear Corner Light Set
    1GA Clear Corner Light Set $65 + shipping & paypal fees* all mounting tabs are intactYou...
  • For sale 1g 1GA Talon Grill ( Great Condition )
    1GA Talon Grill $55 + shipping & paypal fees* Great Condition !You must be registered to see...
  • For sale 2g 2G OEM Door Handle Set ( includes seals )
    2G OEM Door Handle Set $55 + shipping & paypal fees* includes both seals* found a flaw on...
