Ecu???????help
There is an error code that the ECU will throw that will tell you if it's bad. Check out www.vfaq.com under electrical to learn how to retrieve the codes.
Most of the time a bad ECU will not give an error code. There is no test other than swapping with a known good one, opening it up to look (and smell) for leaking capacitors, or send away to an ECU repair place to have tested.
