ECU going emisson mad
_Madman_
327
Oct 14, 2004
Riga, Europe
Hi, I recently swapped my ECU to a 98/99 one and I have 6 diagnostic codes I would like to get rid of.
As far as I've found out, emission equipment should be on all DSM's, but there is something weird with mine, so I would like to hear your opinions on the situation.
From the visual index of 2g it seems that the intake manifold on my car is different and some stuff is simply missing.
The codes I want to get rid of are:
Updated: 22:44:19
6 Diagnostic Trouble Codes Found:
P0135 Heated Oxygen Sensor Heater circuit Bank 1 Sensor 1.
P0141 Heated Oxygen Sensor Heater circuit Bank 1 Sensor 2.
P1400 Manifold Differential Pressure Sensor circuit.
P0443 EVAP System Purge Control Valve circuit.
P0446 EVAP System Vent Control.
P0403 EGR Solenoid.
As far as I understand, the EVAP hose is there (3 hoses are connected to intake tube).
But EGR and Manifold pressure sensor seems to be missing... And there is no place to bolt the second one?! :confused:
EDIT: link to related discussion -> http://www.dsmtuners.com/forums/newbie-forum/307384-injector-plug-swap.html
