2G ECU for Eclipse 97 RS Auto
Aztareth
Nov 15, 2022
Caracas, South America
Hi there, I got a 97 RS Auto with no ECU and I've been failing tryin to get one ECU to work with it after buying a few on eBay, seems like I can't find any compatible I need some help to identify the correct one or some kind of guidance into the right way
Any of those listed would be compatible? Can't find any online chat on the site
All ECU's for a 97 RS will have the same connectors. The only difference between them is internal programming, like having cruise control or not, clutch safety switch or not etc. Why did the ones from Ebay not work?
All ECU's for a 97 RS will have the same connectors. The only difference between them internally is having cruise control or not. Why did the ones from Ebay not wor
All ECU's for a 97 RS will have the same connectors. The only difference between them internally is having cruise control or not. Why did the ones from Ebay not work?
At the repair shop they said that it was for Manual transmission and it dint worked with the ECM of the Automatic Transmission, I've already bought 3 different in eBay with no Luck
