ecu and tcu location
b-nizzle420a
Mar 7, 2008
coweta, Oklahoma
ok i have a 1997 gst and i cant find the ecu and tcu i was just wanting to know where they were......
Look behind the radio..I think its there. remove the side panels on the center concel(sp?) and you should see it
i found two one is by the radio and it a gold looking color and the other is close to the fire wall and its gray....which is which
For the 420a's the ECU is located in the engine bay. Pop open your hood. Look to your bottom right. You'll see it next to your air filter box I believe. You can't miss it, its a square box.
For all 2g turbo models the ECU is located behind the radio. You have to take the foot panel off to access it.
how much does a used tcu usually cost?
