eclipse to talon rear conversion
93ETGOCART
482
Aug 28, 2008
stotts city, Missouri
ok so i know there are plenty of threads on the talon to eclipse conversion but i found a 2ga rear end off a talon in my local salvage yard for 100 dollars for the bumper cover, tail lights, and center section. i really like the talon rear more ### the reverse lights and license plate bracket isnt in the bumper cover. so what exactly would need to be done? i know i will need to move the center bracket for the bumper at least but will i also need to move the sides? also will i need to drill new holes to mount the tails and center section? thanks in advance oh ya im doing this to a 95 rs
Pretty sure the side brackets would have to be moved as I think they would get in the way of the larger talon tail lights. To install the center section you will need to drill holes in the body for the lower bolt(studs) to go through. Then you would have to make any necessary wiring/ connector changes for all the lights.
