eclipse gst smoking
caseclipsegst
54
Nov 13, 2008
pearsall, Texas
Took my eclipse out for a ride with out the arm from the wastegate hookup to the flapper (forgot to put the cotter pin after i installed the 16g):ohdamn: ow my eclipse is smoking a grey color and smells like oil burning... is it possible i blew the seals?
Very minimal shaft play side to side... none in and out
Also it does not smoke rite away when i turn the car on. It is after i drive it for a few minutes... any suggestions?? Before i buy a rebuild kit and where do yall recommend getting a turbo rebuild kit from?
Bump
If it is smoking after the car has warmed up, then it sounds like valve stem seals to me. If there is no shaft play on the turbo, I wouldn't worry about it. You would know if the turbo oil seal was gone. You would find oil when you took off the intake pipe to check shaft play, and oil if you took any coupler off the intercooler piping
+2 on the valve seals, my car did the same thing, wouldn't smoke right away, but once you got driving and would come to idle it would start smoking.
