EBC wastegate
Rsawd95dsm
1,180
11
Feb 21, 2008
Zeeland, Michigan
Have a question on running an Apexi and a tial WG. The tial wastegate I have has a ton of ports on it. It has 2 for cooling which I'm not using so those aren't an issue. Now it has 3 ports around the WG that are all connected and 2 up top that are connected to each other. I've been reading on how to connect the lines up and I'm a little lost.
So COM to the top of the Tial
NC hooked up to vacuum source
NO open to atmosphere
Then the bottom of the WG sees vacuum? Doesn't make much sense. Any one have any info on this?
Here's the pic of the WG I got. The 2 ports on the top see the same air, the bottom right is for water, (which I won't use) and the bottom left and there's 2 more around the housing all share the same ports.
