Ebay oil and water line kit???
bsbllfit7
1,104
3
Feb 17, 2009
Salem, Oregon
they look like they would work,
if you dont mind me asking where did you get your 14b and j pipe?
i would recomend you some other stuff as them lines look just like any regular lines but you can never be to sure about ebay stuff.
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Oil Feedline Kit (Oil Filter Location): Mitsubishi Eclipse 90-99
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Oil Return Line Kit (Socketless Hose Fitting) : -10AN
sens you have the j pipe you can by this,
if you are able to return the jpipe, get this one.
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Extreme PSI 16G Install Kit V2: Mitsubishi Eclipse 95-99
the jpipe alon is around 80+$, so you get the rest for under 50$ each well worth it when your bying it from a good place+ all the gaskets.
those look good for the money and i dont really see too much that could go wrong for that price. the jj pipe i got from a user on ebay who sold me the 14b. Also with the stock fuel system is 14 psi ok for our engines??? sorry for the multiple questions just find it easier to do all in one thread
you should be fine at 14psi, but I would look into a wideband soon
you should be ok, i like braded stuff, everything in my car is braded, but you need to know how to work with that line.
you can use the push-luc style as well it works just as good.
extremepsi is a really good place to by from, you can always give them a call and ask them to give you a price for the kit with everything but the jpipe.
