ebay datalogging palm help
BOOSTn20psi
120
Nov 20, 2004
Aloha, Oregon
I've just got my palm in and the instruction don't seem to work out that great.
Can someone help guide me thru with this palm? Its a Palm m 100 and uses Palm'n'stein (v5.2)software.
I took the car out for a drive and every once in a while I see O2 at .03V and goes to .9V and I sometimes see timing at 25. When it idle sht trim said 0 and lng trim said -12.
I don't know what these mean?
Mods: 550cc, to4 Garret hydrid turbo, all other bolt ons, big Greddy FIC, base fuel adjusted to 40psi, running 12psi of boost.
this is my logs when I tried to follow the forum, at idle I get,
RPM O2 Timing TPS Air Flow sht trim
1150 .75 ,,,15,,, 1 ,, .57,,,,,,, 6
1512 .15,,, 20 ,,, 3 ,, .69 ,,,,,, 10
2120 .14,,, 30,,, 6 ,, .86 ,,,,,, 3
2419 .89,,, 33 ,,, 7 ,, 1.02 ,,,,,, 0
3109 .65 ,,, 33 ,,, 3 ,, .56 ,,,,,,, -5
what does this mean? I'm I doing this right.
SAFC2 low at 800Rpm @ 0 than from 2000rpm increases to -4 than -9 across the board.
high at 800 Rpm @ -8 to 2000rpm than increases to -11 than -16, and -22 across.
turbo don't hit full boost until 4000rpm
help :coy:
