Ebay datalogger ? and yeah, I searched
khartley
1,235
Jul 20, 2004
Faith, South Dakota
Yeah, I got that Ebay datalogger pkg for a 1g, and I can't figure out where those three female plugs go, one is red and has a green one attached to it, the other is black.
I did a search and found some somewhat useful info, but I'm still confused. So I'll post pics, and if someone could photoshop one of the pictures so I know where they go, it would be much appreciated.
Ok, maybe I'm just more stupid that most DSMers, but I don't see how that helped me. I need to know where to hook those 3 female plugs, but I don't know codes and numbers, I would need a picture of them hooked in the car, not a graph or a pencil sketch with numbers.
None of the wires on your harness goes to the fuse box since they're all female.
Oh, ok, well the reason I asked is cause after excessive searching I found this picture, but I don't know if it's the same for my car or not. And it shows the power wire going in the fuse box. So maybe it just doesn't matter where the power and ground wires go, as long as that green wire is in the right spot.
Sorry I didn't get to this sooner.
You're right - the ground wires (the two connectors on the same wire) can go on either of those two pins.
The data connector goes in the top left, as shown.
My eBay datalogger cable didn't have a power connector (I believe it has an internal battery - not sure though).
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
