Easy Question
Booster-Shot
1,184
4
Jul 21, 2005
Napa, California
Hey, does anyone know the specs of the 2 bolts that attach the oil return line to the turbo? The previous owner had bolts that were too long causing a slight oil leak. I broke the bolt trying to get it in any further. Luckily I got it out.
They are two little 10mm's, thanks in advance.
I wasnt really planning on buying the part from the dealer. I was just going to go to a hardware store and pick up something with the same threads. Thats all I need to know.
I think they are M6 x 1.00. I am tempted to say 30mm for the length but I can't be certain. If you have the bolts that attach the return line to the oil pan you can use one of those to test it. They are 6mm x 1.00 for sure and if I remember correctly the length is 25mm.
