e-manage and 6 injector setup??
Ajax
822
Nov 13, 2003
Sioux Center, Iowa
That is the question. I am in the process of putting in my turbo setup. A PTE 50 trim setup. What my shop talked about is that I can use the e-manage to run two more injectors with my stock 4 injectors? Or should I just use the Corbin 8 injector setup and control the secondary set with the emanage when boost kicks in. Or should I just get 440's or bigger and use a normal four injector setup? If I can remember right an emanage can only run 150% bigger injectors right? Would that be sufficiant for running this setup? Sorry I know I should know this but I am in class right now and listening to a bunch of boring presentations, and thought I can ask the question. Dumb question but thinking by myself can you even run 6 injectors were would you put the other two? and if you cannot do so what is the point of having this function then. I hope this makes sense and dont make me look to much like a noob. Thanks
6 injectors?u might as well go with 8,hrc has there new portfueler(8-injector setup)its a complete bolt on and preprogramed for ur setup.its will go well with a built bottom end,hrc is pushing 380whp with the portfueler & 20g turbo...it will cost u roughly 950.00(a lil high) but worth it.
