420A Greddy E-manage?
Riceboy
55
Jan 25, 2004
LaPorte, Indiana
Hey i found a good deal on a greddy e-manage and i hav a 1995 eclipse RS getting rdy 2 turbo i was wondering if this is a good fuel managment system 2 go with? or if i should just wait and get a megasquirt?
Thnx 4 any help guys
Terry :dsm:
Terry :dsm:
hey bro, sorry i never called you back i forgot to save your number so i didnt have it when you left the message. what did you need?
there is a big 2 part review in the review section of 2gnt for the e-manage, check that out.
the emanage works very well, my friend has one in his srt4 and it is alot easier to program then say a safc. for instance if you had bigger injectors you could just put in the size injector in to the emanage and it will adjust to what you have set for every thing else.
the e-manage itself is not expensive
BUT
all the conector and adapters your have to buy for the e-manage can get pricey depending on what you buy
also
I have not heard anything negative about it also
BUT
also
Well i found an e-manage 4 $200 with the support tool do u guys think thats wtrth it then i can go with the ignition harness and map sensor? but doesnt the main and injector harness come wit it? or can u just wire it in2 the main harness?
Thnx guys
Terry :dsm:
  • Wanted 6 bolt NT water pipe
    • chrisman287
