E-Brake sensor
L2RTSiAWD
Honorary Moderator
11,533
29
Apr 8, 2002
Chandler, Arizona
For some reason when ever I break the E-brake light comes on and then I accelerate and the light goes off. There is probably something loose but I don't know where to look.
That's not an "E-brake" light. It is a hydraulic brake warning light and also is used to inform you when the parking brake is set. When braking what is probably happening is the fluid level in your resevior is low and the sloshing around makes the float go up and down, thus turning on your brake warning lamp. Take off the top to your brake resevior, push the rubber seal back in so that the rubber is all the way in like the picture below. The two pictures in the following posts are the improper position for the rubber.
Partially out of place.
This is how I found mine tonight after removing it. This is after about a month and a half since the last time I checked it.
Props to ya man.
That was exactly the problem the lid was messed up and the resovoir was bone dry.
OOPS, you beat my post. I was just going to write "check the fluid level in the RESERVOIR. RESERVOIR. RESERVOIR. RESERVOIR. RESERVOIR. RESERVOIR". [from the root word: reserve] .... No, I'm not being a 'smart ass'.... I looked it up in the dictionary!
Anyway, as long as we're on the subject... my e-light doesn't light when I set the e-brake. I pushed the float down in the famous reservoir and it still didn't light......... so it's probably the bulb, right? I figured that it was a good test rather than needlessly taking apart the e-brake switch.
I had the same thing John, I never new it was a light for your brakes. I always thought it was my ebrake. And I never knew that about the cap....
Props for the pics man. I love learning!
Sure. I like sharing the knowledge. Although I could teach myself out of a job. Regardless... I'm trying to help my fellow DSMers. Honduhs suck!
On the light... that's a good possibility that the buld is out. There's also a switch on the bottom side of the brake resevior that could be bad. I would imagine that the float being down, completes the circuit to turn on the light. While I don't recomend just jumping the two without checking first... that's probably what I'd do. It's up to you. Jump the two wires in the connector for the float or pull the cluster and check the bulbs. Just swap it with the another light that comes on during the bulb check and see if the problem goes to another bulb.
Doug
Yes, I'll swap the bulbs as soon as the weather improves. I'm a wuss in the cold!
Doug - Also, during the bulb check, my battery light is dim [it has always been] and has NEVER gone on, even when my last 3[!!] alternators have stopped generating. Is that normal? And again, at bulb check, the low radiator light lights yet the reservoir can be bone dry and --- no light appears. Is this probably the switch under the reservoir? Please respond with a private message [to laserblue] since these questions are off the topic of this post.... and I don't want to 'clog up' this thread.
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
