Dyno'd My DSM
It's running 25psi on a T04B V-trim. A little smaller then a 50 trim.
AFRs were a solid 11.5 and no knock, 114 octane.
I'm hopeing for high 11s.
those are good numbers, but mustang dynos usually make your car's numbers look better, not worse.
You're thinking of a Dynojet, I've never seen any dyno with higher numbers than those from a dynojet. Of course each dyno is different from the next.
Aren't those injectors a little big for that hp level?
If you want a Dyno with high numbers go see SBR LOL
And he's got the AEM so I doubt it really matters what size injectors he runs.
He's running 114 octane. I'm runing VP103 and I'm tuned to 12.5:1. I make pretty much the same horsepower as he is but on big 16g.
I'll do that when I have a timeslip for a reference. Back to topic, 12.5 is fine on race gas. You'll pick up some nice power when you go from 11.5 to 12.5.
Yes 12.3-12.5:1 AFR will definitly see some good power on C16. I wouldn't kept it their for pump at any boost level cept under vacuum.
