NJGSX96
- 745
- 2
- Dec 11, 2001
YMB,
New Jersey
Well i finally got to dyno the 1G. It was a long road to get her there and I have a few issues to still iron out. Quick recap: Last night I replaced the clutch fork which decided to break on me 2 days ago. Changed the tire that blew out 3 days ago alos. In the process, I noticed my brand new FRH intake manifold was cracked on the bottom, about an inch wide. Either happened when the bolts backed out that hold the plenum to the runners or when I installed new bolts, perhaps I over tightened them. Either way, a new one is on the way. I am sure I have a ton of boost leaks too, which I still have to check for. Rgardless, I got the car on the road at 3:30AM and got to bed at 4:00AM. Got to BMTranny in NJ to use their AWD DynoJet at noon.
Bit on the car: 1G, 264/264, 2G pistons, TD06 internal gate 20G, FRH intake, 3" exhaust, 650 inj, VPC/AFC, Supra FP, Adj FPR base 43psi, Tial BOV, FMIC, blah, blah, blah.
Off the street settings, pump gas and 19psi, she put down 341WHP/276WTQ running a pig rich 10.0 as shown by the wideband. I then made a few adjustments to the fuel and upped the boost to ~22psi, but I got so much knock and timing retarded that it messed up the run. 332WHP/282WTQ on the second. With a little fine tuning, I am sure I could've squeezed out another couple HP at 19psi, maybe 20psi, but this was more just to see where I was at for a nice baseline.
Should my torque be higher? Seems a little low. I was told it should be closer to th HP number, but I do not know. Anyone care to check out the dyno plot and give me some feedback?
http://www.dsmtuners.com/gallery/showphoto.php?photo=17093
Overall, I am pleased with the results. Add some race gas to the mix and up the boost and I hope to see 400WHP. The car needs a little attention as I mentioned before, so hopefully after I check for leaks, fix the intake, fix my starter which sounds like a dying squirrel and button up the car all nice, I will be going back to dyno with some race gas.
