D_Eclipse9916
- 1,430
- 16
- Mar 4, 2004
Vienna,
Virginia
Alright so im in middle of doing a bunch of things and of couse I happen to have friends over and not paying attention when taking everything apart. So I lined up the timing marks down below and made sure the cam marks where together and took off the belt. Well now im installing it again and I realize the dowel pins are facing straight down in the 6 oclock positions instead of where they are supposed to be at 12 oclock. Does this even matter? The cams havent moved as I had them ziptied and ziptied wrenched on so I know they havent moved.
goddamn I feel like a newbie. I was just want to make sure that its alright to go ahead and just make sure cam/balance shaft/oil pump timing marks are correct and the cam mark are correct with the dowel pins straight down and go ahead and put on the belt.
7-bolt 2g with bc 272/272.
