cwack29
- 0
- Sep 18, 2008
Avondale,
Arizona
To start off the car is a 98 gst converted to awd, check engine light came on with these codes, P0300 Random misfire, and P0450 Evap emmisions control pressure sensor. Now in the manual it says that the P0450 is specific to the 2.4L and this sensor is only shown on the 2.4L gas tank whereas the awd tank has no sensor on it. When light came on I was on the highway cruising about 70mph and engine started misfiring and running lean acc to my AFR gauge (about 17:1) Car seems to run fine around town. Also there is a code for the fuel pressure regulator solenoid, I recently added a fuel lab FPR without reinstalling the solenoid as the new FPR adjusts itself to vacuum or boost, is this OK or should the solenoid be installed?
Is it possible that the computer was swapped with one from a 2.4L, and this code is actually something different? I still have the vent solenoid from the gst and routed it to the evap line coming off of the rollover valve on the tank and runs to the canister under the battery. I'm stuck so any info would help!! Thanks
