dsmphaze would like to say HI!!!
dsmphaze
Feb 1, 2011
Las Vegas, Nevada
hey DSMers,
names phaze, my girlfriend has recently acquired a 92 laser rs, auto, non-turbo. recent project of ours now, while i undergo head swap for my 00 neon. it's red, just sprayed the hood nd trunk blk to match the blk roof, sprayed steelies blk w/a cupcake pink lip (what, i told you its my g/f's). looks pretty clean now, cause b4 when we bought it its was hideous. we are just hitting the dsm scene, nd have encountered a problem.
seems that the mechanic that put the car together b4 we bought it used the wrong bolts to bolt up the tranny bellhousing to the block. So, those bolts came loose and the bellhousing cracked because of the tcc, replaced the bellhousing with another from a spare tranny and replaced the starter, the dust shield from the bellhousing to the block was all torn up, so that was tossed. Then a couple days on the road after, same thing happens (yes, by this time we already had replaced the bolts with the correct ones). Problem, went to autozone for a pic of the actual tcc thats suppose to be in there and its different from the one we have in. the tcc that is in there is a 3bolt that attaches to the flexplate to the 6bolt on the crank, now where can i find a 4bolt flexplate that is suppose to be there when i buy the new tcc? for now project dsm is down, and so is project neon. any help or suggestions would be appreciated.
alright, so after all of this was taken care of, two days later...
driving around town, heard very VERY loud metal to metal grinding, acceleration is getting harder to make the car go nd idles with this sound of metal grinding. Eventually car shits out AGAIN at a stop light, gets towed to residence and now disassembly of the same problem happens, bellhousing to tranny is cracked again. What could these symptoms be? is it the TC or problem with the crank or is it the same problem of the flexplate that connects the TC to the crank? possibility of selling the vehicle as a shell if expense is going to be ridiculous. then i will have to wait til i get a 99gsx or rs. any input would be appreciated.
