ECMlink DSMlink screen shot request?? please help
Hmmmmm... I just noticed something. After your last pull when you are coasting, the WB still shows ~10-11:1. It should go full lean to like 18:1 until it hits your idle RPM. Your WB may be acting up.
What does it show under idle?
You also needs to adjust your TPS, it shows 2% when you are off the gas.
Add idle switch to your log.
hmm i didnt notice that either.... at idle it works fine sits at 14.7 with the usualy minor fluctiation. and if i put my tps at 0% then up top my wot is 98% but ill try to get some more logs begining of next week im heading to indiana after work tomorrow so.. ill see what i can do
sry took so long, i tested the wideband sensor and it tested out fine according to that video. I also put the stock fuel pump in the car with the same results except leaner so i lowered the boost to 10psi and yet lean as hell??? idk whats going on with it but im about to try to ebay somethings and try to get enough to get a prosport incar fuel pressure gauge
