DsmLink or EcmTuning help!!
Megasquirt will be your best option but it really needs a good understanding on wiring and probably building your own megasquirt or putting it together to save some money. Also you can use something like AEM FIC.
Well what are your plans? Are you going turbo or n/a? Depending on your goals and what you plan to do will tell alot. People run turbos on the 420a with a stock ecu but you need certain things to make it work. Which if you search on here or Google you can find out what's required.
