Dsmlink, could use all the help I can get
Yelwarc-
52
Aug 6, 2011
Edmonton, AB, Canada
Hey so ive recently installed a few things ( Link, 3"maf, exhaust, aem WB and truboost) and trying to get it to run right, before adding fuel mods and increasing boost. For starters the car runs hot as hell , while setting up timing light it touched the manifLOLd and burnt itself as well as we think shorted it self out ( tried soldering back together, with no luck). My timing seems out of wack and car seems like its really not running right. The afr ratio is almost twice that of truboost at times and I know that's incorrect.Here's two logs in hopes someone has an idea on for where I should go from here.
( near end is the real data (grounded timing and adjusted)
Just to confirm, you're using 420cc injectors, right? You also have no injector deadtime in there, which might be affecting things somewhat.
