ECMlink DSMLink alcohol/water injection
You could use the DSMLink nitrous controls to activate one of the stages of a dual stage WI setup, but you would still need a boost switch to activate the other stage.
Also, because the nitrous control in DSMLink doesn't look at boost, you will probably get inconsistent results using it with a dual stage setup. In my opinion, you would be much better off using two boost switches to run a dual stage WI setup.
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
