DsmLink AFR
erald01
661
Jul 6, 2007
canton, Michigan
How accurate is the reading of afr on dsmlink? Because the one on the program reads 13.96 at idle but lc-1 wideband reads 20.2 at idle, something is wrong here and i can not firgure it out, and i know the car is not running lean.
It's only as accurate as the data it's given. When dialed in properly, it's very accurate and serves as an excellent reference for calibrating your setup. If you're using the V3 software (which works with V2 ECUs as well), then this page explains how to configure the estimate.
ECMLink 101 initial checks
What's the stock O2 say? Is it cycling normally or is it flat lean? What do your fuel trims look like?
You've got a ton of data to use for reference. I'd start with a datalog and careful examination of what it says.
Thomas Dorris
ECMTuning, Inc.
Well the sotry is: When i first tuned the car a week ago, i was getting no readings from the front o2 sensor(burned out), and the wideband was not hooked up so i was not getting a reading from that either, BUT i still tuned it conservatively, SO this week i changed the front o2 sensor, and finally got the wideband to work. SO after doing all these i plugged everything and i started to get the readings that i was talking about previously.
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
