DSMLink 2G
Assuming above post regarding Ceddy mods. If you have the later '97 2g ECU that can be reflashed (is black plastic rather than metal), it is probably the cheapest method, though you'll have to add a reflash pin to the ECU for '97s (98/99 has the connector behind the OBD2 port). Check in the Tuning forum for more info, but you need a Tactrix 2.0 cable (about $150-200), ECUflash (free) and Evoscan for logging ($25). Its relatively simple to use and way cheaper than DSMlink.
