Dry-cell battery charging?
1gDSM4g63
1,808
14
Aug 28, 2007
San Jose, California
How do you charge dry-cell batteries? One time I went Autozone and all they did was trickle charge it and it work fine, but today I went to trickle charge it myself to nearly fully, but it doesn't work. It's even worse, there is no power whatsoever. I think I ruin the Hawker Odyssey! :cry:
You have to have a charger that specifically charges AGM(absorbed glass mat) batteries. The chargers at places like Autozone and Advance Auto Parts can be set that way. Needless to say, you killed your battery.
Hmmm... I wonder how Autozone did it. They charged it with a not special looking Schumacher which looks exactly like mine. Oh well, I blew $120 down the drain. Might as well get a normal size battery and do a trunk installation. The Hawker wasn't working to well for me anyways.
They might have damaged it when they used that battery charger originally. The most common type is a optima so the guy might not have known what to put it on. Honestly they are using the wrong type of charger. The stores are supposed to have a particular machine that will charge any type of battery depending on the setting they put it on. AGMs have to be put on a specific charge setting or it can cause the cells to swell. My first week at work, I put one on the wrong setting and caused that to happen. Then found out what those batteries really had to be put on.
