Drivetrain Vibrations please help
stevehank
Jun 14, 2004
Pittsburgh, Pennsylvania
93 a/t gsx with mods, heres the problem:
Under light throttle, crusing at 25mph, under my feet while driving I can feel vibrations and the wheel shake. It doesnt shake like something is wrong in the steering.
When I give it more gas it smoothens out. Any faster than 25-30mph there is no vibration.
I really dont think its steering, I can take really hard turns and turn all day, and its fine. I think its something with the transmission/drivetrain. The transmission shifts perfect. I can race the car and it runs perfect. The vibrations are only felt when crusing at 25-30mph WITH MY FOOT ON THE THROTTLE, if I take my foot off, it stops. Any Ideas? Thanks alot.
Its probably the famous "rear-differential shim" that goes often.
Or U-Joints or Carrier bearings.
Also, vibrations are always felt at lower frequencies.
I can even feel increased vibration between shifts.
I have a lot of vibration but its because I replaced the fatigued-rubber-dampening-insulators that hold the D-shaft carrier bearing up with washers.
Does anyone know if that was a mistake? :confused:
  • Wanted 6 bolt NT water pipe
    • chrisman287
