driver side wheels shakes and the steering is stiff
TuRBo'DTWiX
120
May 20, 2003
My suspension is pretty much done, it's the stock suspension with 155k on it. The car also needs an alignment but i noticed when i go over bumps and such it feels as if the driver side wheel shimmies or shakes a little wobbly. I tried grabbing at 3 and 9 oclock and shaking it while it was on jacks it didn't really move just a little. The lug nuts should be pretty tight as well. I dont think it is the cv joints because i don't hear clicking. A tie rod maybe? Also i bought my rims/tire combo at wheelsnext.com and they supposedly mounted and balanced my wheels. Each wheel has different number of weights. Is that correct and how should they go, like the 2 with the most weight on the front to wheels? any help would be appreciated. I also noticed fluid dripping very slightly near the middle of the car, transaxle fluid or ps steering fluid?
maybe your rotor/brake disc is lose. If so the only thing holding your tire on is a little cotter pin! Put your car on jacks, take off your rim and you will see a cap about 2in in diameter in the center of your brake disc. Pop thta off with a flat head and check if the big nut is lose. If so tighten it to specs in the hanes manual or vfaq.com Good luck! :thumb:
