Driver side door sags
beauvais87
Apr 7, 2011
escanaba, Michigan
My driving side door on my 1998 eagle talon will close but not well. If you lift up on the handle as you close it you can watch the door move up and then it closes. i Think the brackets are might need new bolts or bigger ones so the door stops from sagging. Any ideals for fixing this?
You need to replace the door hinge bushings and pins. The bushings are brass and can wear out over time. They look like this.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
