Driver side door mirror removal?
Pyramid
115
Mar 8, 2014
Topeka, Kansas
Alright so I got my drivers side mirror in today. now what do I have to remove to get to it? im guessing door panel?
I would start with the little triangle piece that is right above the door panel. I don't remember if there was a plug for the electronics in there or not. It's been awhile.
Like DJ said, pull the black triangle piece out. Then depending on if it's power mirrors or not, there may be a clip to undo. Other than that, it's just 3 nuts to take off. I had my door panel off when removing mine, but I don't believe it was mandatory. GL..
Yeah I had to remove the black triangle thing and then unscrewed my door panel and I could remove two screws but I just got the door panel off and unscrewed the 3 screws
I'm pretty sure the door panels don't have to come off to remove the mirror. Remove the black plastic triangle, and there are three nuts under there that have to come off. The connector should be under the triangle too.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
